586,217 active members*
3,032 visitors online*
    May 2005
    1662
    a very basic fan question.
    A broken cooling fan inside a Sieg mini-mill spindle control box. It plugs into a board with a transformer looking thing. On basic inspection it looks nearly identical to a computer processor fan I have kicking around.
    The sieg fan is marked 12vdc 0.10 A
    The computer fan is marked 12vdc 0.13 A
    For some reason the sieg fan has slightly heavier looking wires. Maybe it's just heavier insulation.
    Any reason this wouldn't be a direct swap? Assume nothing, I'm an electronics moron.
    Anyone who says "It only goes together one way" has no imagination.
    24221
    I see no reason why it will not work, most PC style fans that run off a 12vDC supply are actually brushless, some machines that have 3 wire DC fans often have a fan blade sensor to indicate if the fan is rotating, but then you get a fault if the fan is removed or disconnected.
    The heavier looking wires may be just heavier insulation type.
    If it is the same diam, the air flow rate should be pretty close.
    Al.
    Albert E.
    May 2005
    1662
    And it's a good thing you mentioned that. Looking closer the fan did have 3 wires. Knowing now what the 3rd wire was for, I simply clipped it. Works ok hooked up to a 9v battery.
    Final test comes this evening
    Thank you sir.
  1. Very Basic Question
    By H2ODiver in forum Uncategorised CAM Discussion
    Last Post: 07-27-2007, 02:51 PM
  2. Basic Machining Question
    By asperjack in forum MetalWork Discussion
    Last Post: 05-25-2006, 04:19 PM
  3. Very basic electronics question.
    By RotorRouter in forum CNC Machine Related Electronics
    Last Post: 05-20-2006, 05:35 PM
  4. REALLY basic Question
    By Dongle in forum Mechanical Calculations/Engineering Design
    Last Post: 03-14-2006, 10:47 PM
  5. real basic question.
    By quammi in forum Autodesk
    Last Post: 08-21-2005, 09:28 PM
