586,537 active members*
2,910 visitors online*
Thread: Drip feed?
Results 1 to 6 of 6
    Feb 2008
    42
    Drip feed?
    Hi!
    I just wonder one thing.
    If you have a small memory in the machine so you have to send the program from a computer at the same time the machine is running the program what is the English word for that?
    Is it drip feed?
    Kotten1
    /Sweden
    Sep 2007
    16
    Yes, it is dripfeed. On some CNC machines, the mode will be dispalyed as RMT, DNC or TAPE.
    Want dripfeed software, click here to see the details http://cadem.com/dnc/features-die.htm
    Feb 2008
    86
    Drip Feed
    I use the windows terminal software that came with Windows 3.1. It interfaces well with most older CNC equipment through the RS-232 port. You need to configure the Baud rate, stop bits, parity ect... then its a simple matter of sending a file in DNC mode.
    Jan 2006
    204
    It would help if we knew what machine you were trying to interface to
    archie =) =) =)
    Jun 2003
    23
    Drip feed ability is an optional extra on some CNC controls.
    If your machine has that option, you can use the software from http://www.connectcnc-dnc.com/index.html
    Harry
    Feb 2008
    42
    Thank you for the answer!
    I have a Mazak VQC-20/40B with Mazatrol M2.
    I can transfer the program whit PcMaz for Mazatrol file and Cimco for iso file.
    Do you need a cable with full handshake type when you drip feeding?
    The cable I have is like this.
    PC 9 pin, MC 25 pin
    2 to 2
    3 to 3
    4+6 , 4+5
    7+8 , 6+8+20
    5 to 7
    I don’t now if it’s right cable to drip feeding but I will try that then I’m back from my vacation.
    Kotten1
    /Sweden
  1. Drip feed?
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 02-25-2008, 05:33 AM
  2. Drip feed for Fanuc15M
    By ak762 in forum Fanuc
    Last Post: 12-18-2007, 07:53 PM
  3. BMC-20 w/Max II drip feed......
    By GPena in forum HURCO
    Last Post: 10-31-2007, 06:37 PM
  4. Drip feed Boss9
    By pcsimp in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2006, 01:38 PM
  5. Drip Feed
    By camtd in forum Surfcam
    Last Post: 08-01-2006, 12:09 AM
