Hello,
Is anyone familiar with howto test a TRS drive? I finally have my spindle drive working and now 1 of my servo drives keep faulting out on OCP or OVC alarms. When the machine is first turned on it is stable for a few minutes. After that the y axis will start to get unstable and then it will kick out with the alarm. I swapped the AXO4 card to the x-axis and the error followed the card. I have the test procedure from Mitsu that tells you to check with a scope but I am not clear where to connect the ground for the pins.
Thanks for any help,
Cutmore
