586,106 active members*
3,105 visitors online*
    Aug 2004
    9
    Work has commenced, many questions
    Hey guys
    I have started to build a CNC machine and have a few questions.
    My machine is made out of Aluminum, and has a working area of around one A3 sheet of paper.
    I have linear bearings for the X and Y axis running on 20mm High Tensile Precision Ground Bar. The Z axis is using sintered brass sleeves on 1/2 inch PG bar.
    The first couple of questions have to do with the "ball screws".
    Is the machine best made with the same pitch threads?
    I am not using proper Ball Screws yet but have decided to use precision threaded rod with wide Brass Nuts, Two nuts on each rod with a spring to seperate them. and a housing around the two.
    I am hoping this will be suitable to reduce backlash????
    Any comments??
    Cheers :cheers:
    Tabor
    May 2003
    323
    Dear Sir:
    Can you tell me the size of "A3" paper? Also what is a "PG" bar?
    Regards,
    Jack C.
    Aug 2004
    9
    A3 is Approx 11.5 x 16.5 inchs
    PG bar is just precision Ground Round Bar.
    Tabor
    May 2003
    340
    If you use belts between the screws and motor then you can match the mechanical advantage of each. So if one has half the lead/pitch of the other you might use half the gear ratio. If you are going to run direct drive with steppers then probably best to keep X and Y pitches the same.
    Graham
  1. Questions - Micro CNC router?
    By DarkWolf in forum DIY CNC Router Table Machines
    Last Post: 10-22-2004, 03:24 PM
  2. Work Holding Methods
    By InventIt in forum DIY CNC Router Table Machines
    Last Post: 09-14-2004, 09:13 AM
  3. What is 2.5 d work
    By Patrick2by4 in forum DIY CNC Router Table Machines
    Last Post: 07-05-2004, 05:04 PM
  4. A few honest questions
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-16-2004, 12:24 AM
  5. BPort Series I and VFD questions
    By NeoMoses in forum Uncategorised MetalWorking Machines
    Last Post: 09-24-2003, 04:47 PM
