586,537 active members*
2,969 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > 2nd generation DeskCNC controller now shipping
Results 1 to 14 of 14
    270
    Exclamation 2nd generation DeskCNC controller now shipping
    Today we began shipping the 2nd generation, DeskCNC controller.
    This is a 125,000 steps per second, step and direction, Windows OS controller. It has flash reprogrammable firmware which is updated with the DeskCNC software. The board is 2 x 2.5 inches. All operation is through the serial port.
    The controller supports 7 relay outputs (CW, CCW, Flood, Mist, Aux1-3), 8 switch inputs (4 axis simultaneous homing, e-stop, feed hold, probe/limit, and cycle start), and a 5v PWM spindle speed output. It has 4 axis continuous motion contouring. Machine configurations include rotary 4th axis, slaved linear 4th axis, and 4 independent axes for foam cutting.
    The board also has a quadrature encoder connector. This function will be activated in the near future with capabilities planned for lathe threading, manual jog control, and torch height control.
    DeskCNC is a CAM programming system with contouring, pocketing and drilling, 3D surface machining, PCB tracerouting and drilling, image acquisition, editing, engraving and carving, and text engraving, a standalone editor/simulator, and a CNC machine controller. Specialized programming routines have been added for 4 axis foam cutting, including island salvage, and 3D rotary axis ring cutting.
    The controller supports integrated probing with automated surface scanning, compensation for probe tip diameter, and creation of a 3d .stl surface file. It has cutter compensation (G41/G42), tool and work offsets, drill cycles, and program subroutines. An api is available for some user customization of controller functions.
    Requires Windows 98 or later, recommended processor speed of 200 MHZ or faster, and 16 meg ram(128 Meg ram and faster processor recommended for 3D surface manipulations).
    Additional info at:
    DeskCNC 2nd gen controller
    Fred Smith - IMService
    6855
    Very, nice can't wait to get my hands on one.
    779
    Maybe someone can do a review when they get one
    Nov 2003
    299
    Is this a motor drive or do you need a motor driver (like Gecko/Rutex etc) in addition to this? Just wondering
    6855
    It's a interface between the windows, software and the drivers.
    Apr 2003
    372
    DeskCNC does have driver boards to compliment their controllers as well, they do a small servo drive 35V 5A and a micro stepper controller board. They will soon be releasing another motor drive product, yet to be disclosed.
    "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
    Greetings From Down Under
    Dave Drain
    Akela Australia Pty. Ltd.
    Apr 2004
    439
    i would too like to know if anyone has tryed this out yet how was running at 125k ? been thinking about getting one so i can up my speed and remove my stepmutiplexer
    270
    Quote Originally Posted by Kookaburra
    The SV500 is a single axis, step and direction, servo Driver. It is rated at 30vdc max and 5 amps. It has automatic current limiting and thermal protection. The PID loop in contained on each board and there is an enable line that faults all axes if one faults.
    SV500 servo driver info
    These motors were spec'd to match the SV-500 servo driver boards:
    Servo motors and power supply kit
    We also have an inexpensive 4 axis stepper driver, based on the Allegro A3977 chip. full, half, quarter and 1/8 micro stepping.
    4 axis stepper driver board
    Christian Guest
    Is this controller compatible with the Galaad software and Gecko G201 drivers? Interesting to know coz I'm thinking of switching from software interface (Mach 2) to a hardware one.
    -Christian
    270
    The controller includes software and hardware. It can use the G-codes created with Galaad to run the machine. Galaad cannot be directly coupled to the controller.
    DeskCNC can also create it's own G-cdoe programs, so you probably don't even need Galaad to do that.
    Feb 2004
    2337
    Please correct my understanding here.
    With this device it allows the computer to talk faster to the stepper drivers.
    So the best Mach2 can do is 45000 sps, then this will allow for nearly 3 times that speed with Desk CNC.
    Am I understanding this correctly?
    I guess an advantage is that you can gear down your machine more but still drive it as fast ( Given that the steppers go fast enough) This will give finer resolution without speed loss. ??
    270
    Quote Originally Posted by ynneb
    Maybe
    The DeskCNC controller is dedicated hardware up to 125,000 steps per second. It can be run well at any lower speeds too. One of the places where this is useful is that there are many servo motors around with hires encoders. With 125,000 steps per second, the encoders are still useful and won't need replacing to use the motors.
    It also triples ( compared to the old DeskCNC board which could hit just over 40000 sps) the rapid speeds that can be achieved on machines like plasma, lasers, and routers.
    http://www.cadcamcadcam.com
    Apr 2003
    372
    Benny,
    When you come to see us at the show, I can tell you all about it. It is really nice stuff.
    Dave Drain
    Mar 2004
    40
    good!!
  1. Deskcnc users, what CAM software are you using with this controller?
    By Idle hands in forum DeskCNC Controller Board
    Last Post: 05-06-2006, 07:00 PM
  2. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  3. 2nd Generation CNC Router Design 32.5” X 14” X 6”
    Last Post: 03-24-2005, 11:46 PM
  4. Foam Cutting Mill (2nd Generation)
    By FrankG in forum DIY CNC Router Table Machines
    Last Post: 11-28-2004, 02:32 AM
  5. 2nd Generation DeskCNC servo driver released
    By imserv in forum News Announcements
    Last Post: 11-25-2004, 01:22 AM
