Hi
We have been trying to make our own flat bed laminator. The laminator (is suppose to) work like this:
- The table is 6 meters long and 1.5 meters wide.
- There is a gantry with a 1.5 meter roll that will press the laminate down on the media.
- The roll is suspended by two airpumps that lifts it, or gives it up to 6 bar pressure down on the table.
You can see a simallar maching at this URL:
http://www.rollsroller.se/
The table should be as flat as posible, but needs to be 100% flat along the roller, or there will be bubbles and/or wrinkles in the lamination. This is what we are having trouble with.
So far we have tried getting it built with aluminum extrusions, but that was way to soft (you could visibly bend the table with one finger).
Then we built a table using high duty steel shelfs, with a MDF top. We had support every 30 centimeters. The base of the table is only 110 cm wide, so we added mounted wooden blocks that stand out from the table to support the edges of the top, but this was not straight enough eiter.
We are now going to try to lay down square tube steel all the way down the table. We are going to use 60 pieces wich will leave about 5 cm space between them. We have both an acrylic top and a MDF top that we are going to try with.
Do anyone have any good suggestions how to make this as flat as posible. We have been working on this table so long, trying to tweek it to be flat, so its getting kind of frustrating. A glas top would obviously be an easy way out, but it would need to be pretty thick (at least 10 mm i think), so it will be pretty costly.
Suggestions are apprechiated.
