586,116 active members*
3,474 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G-REX > Does anyone know how to take a Grex apart?
    Aug 2006
    1602
    Hi guys, does anyone know how you open up a G100 without damaging the electronics? I'd quite like to bin the Rabbit part and recycle the FPGA and I/O board for use with EMC2.
    Cheers.
    Oct 2006
    323
    Simple, just lightly pry the top cover to clear the end tabs and lift. I find its a little easier starting with the usb/power end first. You have to pry enough to clear the power and usb housings, then just lift/swing the ethernet end to clear the ethernet port.
    I'm very curious on how you plan to implement with EMC. PLEASE share the details, trials and tribulations.
    Aug 2006
    1602
    Quote Originally Posted by 123CNC View Post
    Thanks - it was easy once I realised that the bottom comes off first leaving the circuitry in the top piece. It's a clever bit of packaging
    I have no idea what I am going to do yet - I have an FPGA on a PCI card with an open-source PCI target + Linux driver, so I can toggle bits from software. I guess I could make up an adapter cable to link this to the Grex's hardware in place of the Rabbit.
  1. GREX and G340
    By DNB in forum Gecko Drives
    Last Post: 08-20-2007, 11:04 AM
  2. grex
    By bbrown2005 in forum G-REX
    Last Post: 03-18-2007, 02:38 PM
  3. So what CAN GREX do right now?
    By PeteZ28 in forum Gecko Drives
    Last Post: 03-06-2007, 03:17 PM
  4. Grex and AB
    By efrem in forum G-REX
    Last Post: 07-16-2006, 04:29 PM
  5. Grex 100
    By planeflier in forum G-REX
    Last Post: 05-12-2006, 10:18 PM
