Here is a quick test I did on my X4+, engraving a bit of 3mm Alumimium.
very cool,i also will post those day are in shanghai exhibion show pic.
enjoy it.
Syil.China
Direction,Commitment,Follow through
John.
Good work.. was that your first milling test?... what size cutter and feed speeds did you use.
Look forward to seeing more of your work.
cheers
Frans
This is the first "thing" I've created. My first test parts were random squares and circles.
This one turned out much better.
I didn't do any calculation for speeds and feeds I just set the RPM to 3500 and had it at a conservative 1mm per sec.
good job..congratulation
Hi John,
It looks good! What is the diameter of the disc? My guess is about 3.5 inches?
Best regards,
Regards,
Wes
it's a touch bigger than 1.25 inches.
