586,110 active members*
3,289 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Help to identify another piece o junk again.
Results 1 to 14 of 14
    Feb 2004
    466
    I dont know what this is so I need your help fellas.
    Looks like encoder of some kind.
    Label reads:
    Stegmann Inc. Dayton, OH
    Model 150MA
    P/N 376838
    Serial 00300107
    PIN Function
    1-- +10 VCD
    2-- +10 COM
    3-- UNSUSED
    4-- A+
    5-- A-
    6-- UNUSED
    7-- I+
    8-- I-
    9-- SHLD
    Without a doubt looks like an awsome and absolutely 'cant live without' device.
    As always manufacturer place has all the info right on the front page with a big label "Konstantin please read this, this is what you are looking for" just kiddin. Have not been able to get info on Stegman US/DE.
    I have 3 of those and if it can be used for my project I will use it but dont know what is it.
    Pics attached.
    Konstantin
    Apr 2004
    169
    Looks like a encoder with differential outputs for driving long cables. You should be able to use just the + or - outputs eg use A+ and I+. Connect it up to 10 volts and see what you get on the outputs.
    24221
    Look like a resolver to me, you normally have an exitation winding 1&2 and a sine and a cosine winding.
    By design, they are usually fairly low resolution.
    Al
    Albert E.
    Feb 2004
    466
    tachus, Id love to hook it up but I cant really tell what the output is, what will tell me the output. Is it TTL logic pulses? Any circuit that will be able to count the output ?
    This is my first time with an encoder.
    To tell the truth I opened one of them just to see whats inside and of course the are some electronics, a couple of opto transistors maybe and a glass disc.
    Konstantin
    Jun 2003
    866
    That is a fairly strange object. It is an optical encoder with only one track and a index output. You need two tracks to use it as a rotary encoder -- unless you only go in one direction. With one track, you can't tell if the rotation has reversed or not.
    A resolver has 6 inputs: +/- sine, +/- cosine and +/- excitation. It does not need a power supply input.
    24221
    Here is the Link to Stegmann http://www.stegmann.com/product/incremental/index.html
    If you hook up the 1&2 to 12vdc, if it is a line driver differential encoder you will get a 12v signal from each of the output which should be a square wave, but if it is open collector you will need a pull up resistor (~1k) to +12 on each output. The web site I believe is faxback or email for the info on encoders.
    Al
    Albert E.
    Feb 2004
    466
    Tach ?
    Angular encoder?
    I did emil Stegmann, waiting.
    Konstantin.
    Apr 2004
    678
    OK, we're guessing, so let me too:
    It's an SSI interface (Synchronous Serial Interface). A clock input and a data output.
    You supply the clock at around 200KHz, and get back the position as serial data.
    You can get SSI cards for a PC, like this: http://www.addi-data.com/wEnglisch/p...pci-1710.shtml
    Apr 2004
    169
    Konstantin i was just guessing as well. Can show us a picture of the inside?
    Hook up some power to the plus and common. Check the voltage on all the outputs. If you don't get anything try 1k pull up resistors per Al's suggestion moving the shaft very slowly should see the output alternate low then high. If you get no voltage with the pull ups it's possible it is designed for use in a current loop. Try grounding the negative outputs with the pull ups on the positive outputs.
    Jun 2003
    866
    Quote Originally Posted by ESjaavik
    That's an interesting guess, but look at the pinout again. Would a SSI have two differential outputs? And a large plurality, if not a majority, of quad encoders have their channels named A, B, and I, so it would make sense for a single track encoder to have A and I. Additionally, most manufacturers do offer encoders with only one track, I've seen quite a few on ebay. Finally, it has 2 n/c lines for that second channel.
    Feb 2004
    466
    Quote Originally Posted by Konstantin
    Tach ?
    Angular encoder?
    Pardon for the pun, never intended. I meant "tachometer?".
    Here are few more pics. Finaly a friend lend me his Cybershot.
    Look inside the misterious object. I unsoldered the opto thingie to move the pcb away. I believe there is a sort of 7805 IC just screwed to aluminum base, shown in the last pic.
    Konstantin
    Attached Thumbnails Attached Thumbnails Guts1.jpg   Guts2.jpg   Guts4.jpg   Guts5.jpg
    Apr 2004
    169
    Looks like there is a & b + index sensors with some of the parts (caps) missing for the b channel. It also looks like the output is capacitively coupled. If you follow the outputs do they go straight to the caps and nowhere else? You will need to bridge out the caps if this is the case. It also looks like you should be able to get the b channel working.
    What is the part number on the second chip? (not the 339).
    Apr 2004
    678
    As the marking on the PCB for the missing "Capacitor" is D4, I would assume it to be of the diode type?
    Apr 2004
    169
    I didn't look that close . It does seem to be labeled as a diode. Maybe its a zener "capacitor" for output protection?
  1. one piece foam cutter
    By bladestalker in forum CNC Wire Foam Cutter Machines
    Last Post: 06-09-2005, 12:36 AM
  2. RFQ Custom Lathe Piece
    By Cold Fusion in forum Employment Opportunity
    Last Post: 04-05-2005, 06:09 AM
  3. Can anyone identify this program?
    By Velox_Skates in forum Uncategorised CAM Discussion
    Last Post: 01-28-2005, 07:46 AM
  4. How to identify a Servo motor
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 10-23-2003, 05:42 AM
  5. How do you Identify
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 09-11-2003, 08:41 PM
