586,121 active members*
3,592 visitors online*
Thread: DXF Import
    Sep 2006
    102
    DXF Import
    OK guys I give up, where have you hidden the DXF Import page?
    I'm trying to import a simple AutoCAD drawing in DXF format, according to the Mach 3 manual the DXF Import page is in the file menu, not in mine it aint.
    What am I doing wrong?
    Martin
    Martin
    Oct 2006
    975
    Hi Martin,
    In Mach3 click the 'File' tab on the menu bar, then in the list that drops down select the 'Lazy Cam' option. When Lazy Cam loads click 'File' and then click 'Open Vector File' to import the .dxf file, and you will be able to work on the toolpaths prior to saving the file as a g-code file to use as a program. Hope this helps you.
    Regards,
    Wes
  1. Cannot import!
    By CROSSHATCH in forum Vectric
    Last Post: 01-16-2008, 03:36 PM
  2. import dwg?
    By dewme5 in forum EdgeCam
    Last Post: 01-10-2008, 12:34 AM
  3. DXF Import on EZ-Plus
    By md63825 in forum Bridgeport / Hardinge Mills
    Last Post: 05-03-2007, 03:32 PM
  4. import DXF
    By qmas99 in forum FeatureCAM CAD/CAM
    Last Post: 07-19-2006, 01:08 PM
  5. DXF Import
    By Todd Price in forum Rhino 3D
    Last Post: 06-07-2004, 06:24 PM
