586,655 active members*
4,251 visitors online*
Results 1 to 10 of 10
    Sep 2007
    55
    New Mach3 indexer wizards available
    I now have three indexer wizards available, spiral, wrap on a cylinder and my latest, flutes. The price is $75 for all three. If I make other indexer wizards available in this package in the future, all previous customers will get the new wizards as well. I can be contacted at rgoldner AT iname DOT com.
    All of these wizards use a rotary axis and are aimed at woodworkers. The spiral wizard will cut rope, barley twists, hollow spirals, etc. The flute wizard will cut any number of flutes on a cylinder with or without ramping. The wrap on a cylinder wizard will allow any gcode to be wrapped around a cylinder without any changes.
    Apr 2006
    3498
    can you show us the glimpse of ur software wizard..the input/output parameters etc
    Sep 2007
    55
    I created a quick and dirty website today to try to answer the questions I've been getting. Check it out.
    http://www.wizardsbyrich.embarqspace.com/
    I'll be happy to answer any questions the website doesn't address.
    Sep 2004
    18
    Very nice/interesting Wizards. I have you bookmarked for future work.
    thanks.
    Alfred
    Sep 2007
    55
    New Wizard!
    A fourth wizard has been added to the collection. This one will create any diameter cylinder out of rough stock or larger diameter cylinders. It will also create tapered cylinders.
    In addition, the fluting wizard will now create flutes on tapered cylinders. Even with the added wizard the price stays at $75. Please see
    for additional information or to purchase.
    Jan 2006
    357
    Wow, I will be buying these wizards too!!
    Jun 2005
    142
    wizards
    I got lucky and tested the wizards for Rich. They work great and have saved me a lot of effort.
    Sep 2007
    55
    Here's a couple of pictures of work done with my new wave wizard. The wizard will be released in a few days.
    Sep 2007
    55
    Wave Wizard Available Now
    I am pleased to announce that a new wizard has been added to my Indexer Wizards package. The Wave Wizard is used to cut sine waves onto a straight or tapered cylinder. Depending on the bit used and the pitch and amplitude selected this can create some very interesting patterns.
    The price of the Indexer Wizards stays the same at $75.
    For more information:
    Sep 2007
    55
    Indexer Wizards version 2.0 Now Available
    I am pleased to announce that version 2.0 of the Indexer Wizards are now available. The Indexer Wizards are designed to allow you to cut cylindrical objects on your rotary axis. These objects range from simple cylinders to complex newel posts with tapers, flutes, spirals and carvings. The wizards consist of a few basic operations (called work operations) that can be combined in unlimited ways without having to write any gcode. Work operations include rounding, spirals, flutes, waves, polygons, tool change, wrap gcode on a cylinder and custom. The custom work operation allows you to include custom gcode.
    The Indexer Wizards create one gcode output file that can be directly used by Mach3 to cut the object you have designed. The object is designed by entering the parameters required for each work operation that you want to add to your object. The Indexer Wizards convert these parameters to gcode. At any time you can save your work to a gcode file. You do not have to finish your design in one session. You can save your file and exit the wizards and then, at a later time, reopen the file and finish your design.
    The wizards are designed to allow bi-directional operation. This means that at any time you can open a file created by the Indexer Wizards and modify your design in any way that you wish. You can change the order of work operations, add and delete work operations or change the parameters of one or more work operations. This makes it very easy to correct mistakes or change a design into something brand new.
    A free operation manual may be downloaded from my website.
    BTW, the Indexer Wizards cost $100 and come with free upgrades and support.
    Here is a picture of a carving wrapped around a cylinder. The decorative beading was done with the help of Vectric's Aspire.
  1. MACH3 WIZARDS
    By tpmx57 in forum Mach Wizards, Macros, & Addons
    Last Post: 02-05-2018, 12:57 AM
  2. 4 axis G-code Wizards available
    By Legacy CNC in forum News Announcements
    Last Post: 06-25-2008, 10:02 PM
  3. re jog tab in mach 3 when in wizards
    By woffler in forum Mach Wizards, Macros, & Addons
    Last Post: 02-08-2008, 03:14 AM
  4. can't get the wizards run
    By rodyoca in forum Mach Wizards, Macros, & Addons
    Last Post: 05-31-2007, 02:42 AM
  5. Conversation wizards...
    By WilliamD in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2006, 10:48 PM
