586,036 active members*
3,695 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Sep 2005
    39
    Fanuc 18T LED alarm only
    Controller will not power up, therefore no CRT display. Power supply is on with no alarms, but on the main board LED's the top row is green in all 4 banks with 1 red light in the second bank of the bottom row. Maintenance manual states that it is a generic alarm.
    Had the main board tested by Fanuc and they said it was O.K. Where to look next?
    Jan 2006
    121
    Please observe the LED status on main CPU when you turn on the braker on the machine. See if the LEDs on main CPU comes on as soon as you turn the braker on (this is not normal since they should only come on when control ON is pressed). If this is the case, you have a bad power supply (part number A16B-1212-xxxx). Otherwise please post the main CPU board number so that we can find out the LED status meaning for you.
    Sep 2005
    39
    LED's on main board do NOT come on when power is supplied at breaker (only come on when the power on button is pressed). The only LED that comes on is the single green light on the power supply itself.
    Main board #is A16B-2201-008
    Jun 2008
    23
    led alarm
    i think there is problem of ROM or Ram in machine controller
    Apr 2009
    similar problem
    I have a 18t lathe.
    When I try to power on the controller I get 4 green lights and 1 red light in the second spot.
    Any ideas?
    Mar 2008
    27
    MISMO PROBLEMA EN NAKAMURA
    I HAVE THE SAME PROBLEM IN ONE LAHTE NAKAMURA-TOME-20II.
    MY CONTROL IS FANUC 18TA.
    I HAVE OTHER MANUALS AND PARAMETER OF THIS MACHINE.
    INCLUDE SPECIAL PARAMETER.
    IF SOMEBODY THIS INTERESTED IN THIS PARAMETER I CAN TO SHARE THIS INFORMATION.
    THANK YOU FOR ANY INFORMATION THAT HELPS ME TO LEAVE TO THIS PROBLEM.
    THANK YOU
    ROMMEL ROJAS
    Jun 2008
    23
    970 alarm in FANUC 18i
    I m suleman khosa, i need your help in one matter.
    i have one CNC machine in fanuc 18i system was installed. When I On that machine early in tthe morning then its gave alarm of system 970 NMI occured in PMC LSI. Manual said that replace the motherboard, please give me another solution to repair that unit or any other way of solving problem.
    My email id is [email protected]
    Feb 2010
    16
    Quote Originally Posted by turninjake View Post
    I have a 18t lathe.
    Any ideas?
    I have this exact problem, though with a A16B-2201-0080 board. I had an issue with the Power Supply, and replaced it. Then a couple days later received this error and CRT will not power on. Prior to all this I was receiving a servo amp error #4/DCSW.
    I need this machine up and running ASAP. Any solutions ?
    Quote Originally Posted by Suleman Khosa View Post
    NMI of any sort is normally bad news. I have had before, its simply corrupt data. Try reloading the PMC and Data. If not new board i'm affraid.
    The Fanuc Support Center Team
    www.fanuc-support.com
    Hello to those with the lights on...
    Does the screen come on at all? Even a milli sec? Put your hands around your eyes and get close to the screen, it might actually be on.
    Let me get this right... you have
    g1 | g2
    g3 | g4 (g-green)
    All greens on
    off | off
    off | r4
    only this red is on.
    If so then this is SRAM parity. The four greens mean "Initial status immediately after power is switched on; boot is running."
    My advice would be to hold down the two furthest right soft keys under the screen (6&7).
    If there is a Parity error, it will alarm out in here.
    Sorry if i have mis read.
    Jun 2008
    23
    NMI error
    When I ON the controller then its started some times correctly and some times its stop at red leds 2 & 4. Manual said that both LEDs of SMEM & SFAIL. That time green lED 1 is ON.
    please suggest. Thanks
    [email protected]
    Jan 2010
    HI, I have a Puma 250M lathe with Fanuc 18T and get a 2028 alarm spindle rotation condition is not ready?? Any ideas? Thanks Jim 714 6121480
    Jan 2010
    96
    Question
    Hello. Can you operate the spindle in MDI or manual. Check to see this first. Ill look up the 2028 alarm and see what i can dig up. Check the simple things first. Not but a few things to cause this. Check that the chuck is clamped. If this is physically clamped then check your inputs to see if the clamp switch is being made. If this checks out then check in your program and see if there is a condition in the program that is not being met. Any alarm led's on the drive itself.
    Jan 2010
    thanks for your help! after sniffing around, i discovered that the cover was off of the gear box on the live tooling feature of the turret, and coolant got in and the drive shaft was completely frozen! i disassembled the turret, replaced the bearings, and the alarm is gone.
    Regards Jim
    Dec 2008
    5
    18TA led
    hi sir i have same problem how you short it out all 4led and 2nd red lit
    Quote Originally Posted by Dragonbikes View Post
    THANK YOU
    ROMMEL ROJAS
    Dec 2008
    5
    fanuc 18 t
    I have a 18t lathe.
    Any ideas?
    Dear sir
    i have same problem in fanuc 18TA,
    pls help me how you shorted it out
    [email protected]
    May 2010
    muhammad arif
    Quote Originally Posted by roshanlal View Post
    hi
    Feb 2011
    14
    need parameter
    Dear Sir,
    If possible kindly send the parameter for the same machine.
    thanks and regards,
    Devender Sharma
    [email protected]
    [email protected]
    Feb 2011
    14
    THANK YOU
    ROMMEL ROJAS
    Dear Sir,
    we have same machine,but do not have any manuals and parameter.So kindly send the all parameter list.
    your immediate response will be highly appreciated.
    Thanks and regards,
    Devender Sharma
    [email protected]
    [email protected]
    Feb 2010
    16
    Re: Fanuc 18T LED alarm only
    I know this is extremely old... but what did you ever come up with. I am having the same issue. Thanks.
Page 1 of 2 12
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Fanuc 6T-B alarm 402:servo Alarm
    By leiryll in forum Fanuc
    Last Post: 12-03-2013, 08:52 AM
  4. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  5. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
