I was looking for feedback and not orders, but it is a usefull exersize, so let's go thru it. First question is material. for example:
3/4 x 6 x 48 extruded 6061 $60
same size ground jig plate $160
there are components such as bearings and fasteners.
The size bearings you would use depends on what ball screws you find and some come with the bearings still on the end of the shaft. Also the ballscrew nut mounting would differ.
So, reasonably, I could make a kit for Thompson ball screws or Rex ball screws and you can buy those new from vendors that will do whatever end machining you need.
OR, I could make a kit with blank ball screw mounts and end plates and you would do the final machining on those depending on what you came up with for ball screws.
Slides are a bit easier as they are more standardized... to a point.
So if you can say what material and options sound best for you, I can give you a price. I may even throw in the current Thompson ball screws as I will have no need for them if the Hiwins every actually get here . . . currently they have been lost by the post office . . .
