586,102 active members*
2,543 visitors online*
    May 2008
    17
    Interact 1 mk2 be safe measures
    Hi guys,
    Boy there is a knowledge base here....I am humbled.
    I brought a Interact 1 Mk2 a few weeks ago.
    I didn't see it going, but I am told it was a good goer and it looks like a new machine.....
    Its a Interact 1 mk2 with a TNC155 controller
    I am currently getting the sparky's to wire up the 3 phase to it so I can fire it up.
    Now my questions......
    I am learning it is a problem if the batteries go flat, so how do I change these without loosing the parameters, assuming they are still there.....
    How do I back the parameters up ?....... I am seeing they are a problem if lost.
    I have an electronics background, so I will most likely understand your explination
    Thanks for your time, helping a learner in CNC stuff
    1121
    re
    change the batteries with the power ON. 3 AA's
    once you get the rs232 set up to bring programs back and forth, you can send the parameters out by hitting the MOD key until 'code number' comes up and type 95148 then hit the EXT key, it should prompt you to send or recieve
    May 2008
    17
    Ok, so as simple as that..... machine powered up and in standby mode....and just change the batteries.....
    do you recomend Lithium AA's ?
    also , how long would you think the batteries in it would last....I gather it would have alk batteries in it....
    how often do you guys change them ??
    Jun 2003
    70
    You batteries should last several years.
    Jim Short
    www.tahlinc.com
    1121
    re
    In a macine that is on 8 hrs a day, I have gotten better than 5 years, I barely remember ever doing it. It is only when they sit a lot that the batteries get low. Duracells are fine
  1. change inch welding measures to metric
    By juha in forum Welding Brazing Soldering Sealing
    Last Post: 06-17-2008, 02:48 PM
  2. change inch welding measures to metric
    By juha in forum Education - Teachers and Students Hangout
    Last Post: 06-17-2008, 04:20 AM
  3. BP Series 1 measures of spindle
    By ant771 in forum Bridgeport / Hardinge Mills
    Last Post: 10-20-2007, 02:20 PM
  4. Is this safe?
    By foam27 in forum CNC Machine Related Electronics
    Last Post: 06-16-2006, 12:08 AM
  5. Is it safe?
    By kong in forum Gecko Drives
    Last Post: 11-24-2003, 04:56 PM
