As an avid (read fanatic) wooden wheeled clock builder I have been on the lookout for some time for a nice program that will simply draw up gears that are useful in building clocks.
The clock shown here is 6" in diameter and uses a balance wheel escapement, it was all cut using the CNC I built with a lot of help from this forum. It lacks a case but that is next. Thanks everyone!!
Anyway I have found a good little program (out of the UK) for producing really good tooth forms for gears and its called "Involute and Cycloidal
Gear-Wheel GCode Generator" Its not perfect (need to do some work arounds for Mach 3) but worth working through to make it work. It found at:
http://www.realhamradio.com/gearhome.htm
Any other clock builders out there?
