586,070 active members*
3,409 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Arcs to Circles Lisp Routine
Results 1 to 1 of 1
    Jun 2003
    70
    Step import to ACIS solids (AutoCAD) from Parasolid yields a solid model that will have a 2D representation of holes as two arcs in order to show a circle.
    This AutoLISP routine will remove the selected arcs and replace them with circles. I used to use this in conjunction with TahlCAM's getface routine. TahlCAM'S drill path routine needed circles to represent drilled holes.
    I pulled this routine out of TahlCAM and created a stand alone TahlArcToCirc.fas
    that will work in AutoCAD versions through 2009.
    I hope someone will find it usefull.
    Cheers,
    Jim Short
    Attached Files Attached Files
    Jim Short
    www.tahlinc.com
  1. Cutting arcs and circles
    By inaman in forum GibbsCAM
    Last Post: 04-26-2008, 08:04 PM
  2. Engraving, Tangentail arcs, and crop circles
    By Prboz in forum BobCad-Cam
    Last Post: 06-29-2007, 02:06 AM
  3. Help with AutoCAD LISP
    By studysession in forum Autodesk
    Last Post: 01-10-2007, 02:54 AM
  4. Replies: 32
    Last Post: 05-10-2006, 02:08 PM
  5. Cutting circles and arcs
    By Hack in forum CNC Machine Related Electronics
    Last Post: 11-08-2004, 10:12 PM
