586,537 active members*
2,802 visitors online*
    Jul 2008
    24
    Clock interupt or something?
    Hi, all! I need to interrupt the program with a hard-contact input that does not require a keystroke to continue. I am using QuikStep4 on a INX Pentium2, Win 98. I have looked at a few other programs and none of the ones I have looked at have provisions for this, which I found a little weird. I just need to allow the torch height unit to go through its setup at the start of each cut and don't want to stand there hitting the "continue" button. Maybe a 12 volt solenoid on the mouse button? (yeah, right) Thanks!
    May 2008
    18
    Might be able to connect a relay across the mouse button to basically the same effect, once the mouse is positioned you then use a pulse generator to close the relay every half second or so to make the program continue.
    What is this program waiting for other than user input? Trying to hard wire a contact like what you describe into a computer would be very involved, since not only would you have to make the actual physical device but would also have to modify portions of your operating system
    Jul 2008
    24
    Reason why
    The stand-alone torch-height control I use has outputs for arc-established and pierce-delay. It needs to do its thing before the programmed cut begins. Both of my Burny units have this built-in but I am building this one from scratch.
  1. Optical interupt switch implementation.
    By owhite in forum CNC Machine Related Electronics
    Last Post: 07-26-2009, 10:27 PM
  2. another clock
    By balsaman in forum WoodWorking Topics
    Last Post: 05-14-2009, 02:17 AM
  3. A cnc clock
    Last Post: 01-26-2008, 08:15 PM
  4. Looking for CNC Plasma Clock dxf
    By zeoncomp in forum Waterjet General Topics
    Last Post: 01-10-2008, 01:42 AM
  5. Atomic Clock
    By Al_The_Man in forum Community Club House
    Last Post: 07-20-2006, 08:15 PM
