586,332 active members*
4,189 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Adding 4th axis to Hardinge w/fanuc
    Oct 2006
    15
    I bought a used rotary table for my VMC and now I need to get my VMC to use it. I have a Hardinge VMC1000II with a Fanuc 0i-MB controller. The machine came prewired for a 4th axis. I've picked out a servo drive board for the servo motor (Fanuc A06B-6114-H103). Now I need to look at what else I'll need to do to get the rotary table going. Will I have to modify the ladder diagram? Change some parameters? I know I'll have to cable it and tune it.
    Jul 2011
    21
    Hi bob:
    Could you intall the 4 axis?
    Right now, i am trying doing the same :S
    I have the same servo drive, but the motor that the 4 axis have to use is alpha i motor, what did you do?
    Best regards
    Mar 2005
    816
    I have 8 different VMC's which use different FANUC controls. I would like to add a rotary 4th to them. But I want to set up 4th axes disconnect so that I could then just unplug and turn it off, the the control revert to a 3 axes machine.
    Also I have to find a suitable rotary table (or have one built).
    I would especially like this for the 18i and 16.
    Aug 2011
    2517
    good luck with that! extra axis always requires extra wiring (always undocumented) and secret parameters (always undocumented)
    Mar 2005
    816
    That's what I figured. But whatever I do will be well documented as always.
    Know of any good servo rotary tables under 13"?
  1. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
  2. Adding 4th axis
    By bgmnn in forum HURCO
    Last Post: 05-23-2008, 04:56 PM
  3. adding a 4th axis?
    By airbrush in forum Uncategorised WoodWorking Machines
    Last Post: 10-12-2007, 11:00 PM
  4. adding 4th&5th axis
    By cnc prog in forum Daewoo/Doosan
    Last Post: 09-25-2006, 10:26 AM
  5. Adding A 4th Axis
    By helix77 in forum EdgeCam
    Last Post: 04-13-2006, 08:36 PM
