586,033 active members*
3,079 visitors online*
Results 1 to 6 of 6
    Jul 2008
    RC Car Gearbox Casing
    I have an old 1/9 scale Kyosho Toyota 4 Runner - gas powered, which has a CCVT gearbox (really is a continuously variable transmission with Neutral, Forward speeds and Reverse).
    The transmission is mechanically shifted using a servo.
    However, due to the material used for the case (hard clear-ish plastic):
    1) It starts leaking at the feet (where it's attached to the chassis) because the screw holes crack
    2) The top post where the shift linkage is mounted breaks because the post is plastic and it breaks over time.
    I'm thinking of coming up with a replica using aluminum. It would be stronger and would look way cool (anodized black maybe)
    Challenges are:
    1) A clear plastic/acrylic window on the side would be nice or a dipstick to measure the oil capacity
    2) The internal structure of the shell is pretty complicated
    The seal between the shells does not have to be fancy, we could just use RTV gasket maker
    Attached are some pictures, I will post more details later.
    You can see that in this picture, the top post is already broken.
    Please let me know what you think about this idea. I had taken a class in CAD design (using Pro E) so I could do some of the design if I can get my hands on a CAD software.
    May 2006
    573
    If its one of, wouldn't it be easier to just mill it
    Jul 2008
    Quote Originally Posted by Guldberg View Post
    Don't I still need a CAD design or can I just take the original part to a machinist who can then setup the machine manually?
    May 2006
    573
    You would still need a 3D CAD drawing. When you draw it, consider if the inside could be made simpler
    Aug 2005
    385
    Quote Originally Posted by holson View Post
    Nah, just take it to the shop as is. I do that kind of work all the time and even though the machine shop will have to take dimensions for themselves, chances are they'll do it more accurately than you would at home. Just be sure to bring all the internal pieces too~
    EXIT 85 Manufacturing "The best custom wheels, period" (www.exit85.com)
    Experts in low volume, highly complicated, one-off forged aluminum wheels
    Jan 2006
    4396
    A good shop will have software to make this. Just make sure the shop that does it has a good reputation and remember a one of might cost a lot.
    I two have been doing some work in the RC market and it is a lot of fun.
    Good Luck!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
  1. 90° Beveled Gearbox ?
    By twocik in forum MetalWork Discussion
    Last Post: 06-21-2008, 08:20 AM
  2. Arched casing
    By dannyu in forum WoodWorking Topics
    Last Post: 03-05-2008, 03:15 PM
  3. Check ZX7045 GearBox
    By fcollebluegate in forum Charter Oak Automation Support Forum
    Last Post: 08-31-2007, 08:34 AM
  4. Rfq Acrylic Casing For Electronics (Awarded)
    By naspc in forum Employment Opportunity
    Last Post: 05-30-2007, 10:49 PM
  5. RF 45 gearbox problem need help please
    By fc911c in forum Benchtop Machines
    Last Post: 01-12-2007, 11:56 PM
