586,075 active members*
3,967 visitors online*
Results 1 to 6 of 6
    Jul 2008
    HEIDENHAIN TNC 145
    NEED HELP WITH BP SERIES 1 R2C3 WITH HEIDENHAIN TNC 145. I JUST PLUGED IT UP. I HAVE JUST A LINE ACROSS THE MONITOR BUT I DO HAVE 0"S ACROSS THE XYZ READ OUT AND ALL OF THE RED LIGHTS ON THE CONTROL ARE ON . WHAT DO I DO NOW. I RUN A BP SERIES 1 WITH AN AHHA CONTROL. BUT THIS CONTROL IS NEW TO ME.
    1121
    re
    "CE"
    Power enable [should hear a loud thump]
    Turn the brightness or contrast knobs on the monitor so you can read it.
    cycle start for each axis till it homes[up to six times]
    look at the pretty machine
    turn the power off
    GET A MANUAL!!!!!!!
    I may have a programming manual to spare..........
    1121
    re
    Actually Heidenhain.com, 'OMA controls' and download one.
    You ought to have the r2c3 manual though, they do turn up on ebay
    Nov 2004
    3028
    A line across the screen usually means a defelction amp in the CRT is gone.
    There is a horizontal and verticle deflection amp that bends the beam and paints the phosphors on the CRT making a display. A line means the beam is deflecting in one plane only.
    George.
    Jul 2008
    THANKS, I AM AT THIS POINT JUST TRYING TO POWER IT UP AND SEE IF ALL OF THE AXIS WORK. I DID HAVE THE SPINDLE RUNNING BUT WAS NOT ABLE TO MAKE THE X Y Z MOVE WITH THE JOY STICKS . I DID TAKE THE 3 AA BATT. OUT AND CHECK TO SEE IF THEY WERE OK BUT NOW I CANT GET THE CLEAR BUTTON (CE) TO TURN ALL OF THE RED LIGHTS OFF SO I CAN POWER THE SPINDLE UP.
    1121
    That is because you did not READ. You have now lost all of your parameters. good job.
    Look in the archives, I think I posted a set at some time in the past
    GET THE FREAKIN BOOK
  1. heidenhain help
    By DustyL in forum Bridgeport / Hardinge Mills
    Last Post: 10-18-2019, 08:44 PM
  2. Old Heidenhain DRO Help!?
    By scubasteve_911 in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2008, 03:29 AM
  3. heidenhain help
    By CBNDude in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-24-2007, 10:20 PM
  4. Heidenhain 145
    By kck63 in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2007, 01:25 PM
  5. Heidenhain 150 help
    By tom bryant in forum MetalWork Discussion
    Last Post: 05-19-2006, 03:53 AM
