586,067 active members*
4,749 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Drive for a 4-wire unipolar stepper
Results 1 to 7 of 7
    Jul 2008
    Good morning
    I'm trying to get hold of a drive to control a three coil four wire unipolar (I think) stepper. I've come to understand that this isn't exactly the most common type of stepper, and therefore the search is proving kinda difficult. I'm completely useless with electronics, so building a drive myself isn't something I'd like to do, but it's not out of the question as a last resort.
    The coils have a resistance of 33 ohms each, and they're arranged like this:
    http://users.evtek.fi/~k0301161/Coils.bmp
    That means it's unipolar, right?
    The voltage used to excite the coils is 28V, so the current per phase is around 850mA
    Could any of you point me to a drive that would work with this thing? I've found nothing so far.
    Thanks a lot.
    May 2005
    1397
    I'm pretty sure you will need to make your own. It shouldn't be that hard... see:
    http://www.forth.org/fd/Step.html Figure Two, but drop one of the transistors. Then you have to make your own control signals to move the motor by turning on and off the coils in sequence.
    Jun 2004
    463
    This page has a description of the step sequence.
    http://www.cs.uiowa.edu/~jones/step/types.html
    Also, are you sure it is a stepping motor? I bought some surplus motors that were listed as steppers, but turned out to be 3-phase brushless motors.
    Jul 2008
    I ended up building the thingie myself, and it seems to work well enough.
    It probably wasn't an optimal solution, but I ended up generating the phase sequence in Labview and amplifying it with a ULN2003 transistor array thingie.
    Generating the pulses with Labview limits the motor's speed somewhat (with an older laptop I can get up to ~55Hz/phase), but I get a nice user interface with colourful buttons and smiley faces, so it all evens out.
    Thanks for your help.
    Apr 2007
    1955
    That is an interesting approach - never thought of using labview to run a stepper motor.
    Jul 2008
    Heh, well. When you've got a hammer, every problem looks like a nail.
    Jul 2009
    Quote Originally Posted by Kelpo View Post
    Kelpo,
    I am relatively new to Labview...I am using a Geckodrive g203V (http://www.geckodrive.com/product.aspx?c=3&i=14460) to control a 4-wire stepper motor. I am using a NI USB-6009 DAQ with digital input from the drive. (I am building a tension stage and this motor is turning a threaded rod (1/13 pitch) on a 2:1 gear ratio)
    I am confused how to get it to run with labview...how did you control you steps/pulses, speed, step rate and movement along rod, etc?
    Do you have any examples that you could share. I would greatly appreciate it.
    J
  1. dave, How is 23-200-DS8 Unipolar Stepper 8 wire work?
    By cjchands in forum Hobbycnc (Products)
    Last Post: 03-19-2021, 03:37 PM
  2. Avr Unipolar Chopper Drive
    By H500 in forum Open Source Controller Boards
    Last Post: 01-08-2009, 03:42 PM
  3. Avr Unipolar Chopper Stepper Motor Drive Problems
    By valasoft in forum Controller Cards
    Last Post: 07-13-2008, 03:55 PM
  4. Unipolar Chopper Drive Problems
    By JamesMI in forum Stepper Motors / Drives
    Last Post: 07-10-2006, 04:07 AM
  5. 4-channel unipolar stepper drive
    By k_s_choice in forum Stepper Motors / Drives
    Last Post: 08-26-2005, 06:04 AM
