h
h
Hi ,
I was wondering if anyone had an english philips 432 operation and programing manuals....
I have the manuals in English.
but i don't know what do wanna know about it.
you can email me your problem : [email protected]
did you find the manuals???
dear friends,
please send me which part do you want to know about, because I can't scan whole pages!
also is there any body know about Indromat and he has the drawings of it ?
Thanks all
i will look tomorrow if i have something about the indromats
i bought the machine 1 month ago so i still dont know exactly what i have
Regards
I have a bunch of manuals for the Phillips 432 controls. What are you looking for?
I have 432 control and manuals too, might be able to help series 6 software edition I think.
Hi!
I also have a machine whit Philips 432 controller.
Now finally the machine is starting too talk to me.
I can transfer the program between the machine and PC.
But I don’t now how too choose the program I want to run in the machine.
How are you doing then you want too run the program you have just transfer too the machine?
And how are you doing then you transfer the zero point on the material too G54 in the machine?
Pleas help me!
Regards
Kotten1/
Sweden
You are able to send the Gcodes to machine with CAM softwares like Surfcam, Catia, Powershape,... or you write the gecode in Notepad then transfer them to machine with pcin , winnc , surfcam dnc, ... .
To give the zero point you have to push prog bottom then push menu bottom then push number that's about reference point.
Hi
I got what you mean!
Just push Menu bottom in Manual mode, then push block search(number 1), then push ID Dir (F4) then choose the program name finally push search bottom .
The program number must be seen in top.
program buttton, 1 block select, hit softkey program list? I think, it should show your list of programs, select the program you want to be the active one, enter,
I am not in front of my maho right now but I think this is correct sequence
Is it any one now how to run whit drip feed?
How are you doing then you set the machine in drip feed position?
Kotten1/
Sweden
I don’t really now what you mean.
Then the machine is standing in my zero point. (That position I want to have my zero point on the material) I want to set the machine numbers in G54.
Do I have to write the numbers down on a notepad and then write it manual in G54?
Or is it some button I can press, so the machine can read it by it self and set it in G54?
Lots of button pressing with a Maho !!!!!
I think you have to write the X Y Z B zero positions your self into G54
Does any know if a MAHO 800E with philips 432 control can do circular interpolation?
[email protected]
I would be amazed if it can't, this is the most basic thing that a CNC can do! That is why we call them a Computer Numeric Control and not just an NC, it is the computer's ability to calculate all those points around a circle that in the bad old days an NC program man would have to compute himself!
Just look in your manual for G02 & G03 and there it will tell you how to program a line, or the mc with Philips 432 will prompt you for the info
