586,219 active members*
3,362 visitors online*
Thread: Cold air gun
    Mar 2007
    196
    Cold air gun
    Does anyone use one? If so, how effective are they as opposed to liquid coolants? Thanks in advance.
    Bill
    Feb 2008
    123
    I used to have a small cold air system set up on my Summit mill. It isn't bad at all.
    Within the last few months, I switched over to a small 1gal. Kool-Mist system. The cost was very little and it runs off your existing air, but you get much more cooling to the tool with the air and the mist. You can adjust the mist flow depending on the work done.
    And, with most all of the mist evaporating on the tool or the work, there is no need for any form of catch system.
    IMHO, if you are going cold air, you might as well go mist. Its worth it.
    My Setup
    Mar 2006
    427
    You might find this a link usefull. http://www.cnczone.com/forums/showthread.php?p=404403
    Now I tried this but I miss read the ad when I bought the air pump. I meant to buy a 75l/min pump but ended up with a 75l/hr. Not a whole lot of airflow but I tried it and it did keep the endmill cooler to touch but didnt clear away any of the chips. Now you can find air pumps in ebay under hydroponics. Fish tank airpumps just seem to pull up the smaller ones.
    I would be interested in finding out what you come up with. I also didnt know that misters evaporated that much.
    Mar 2007
    196
    I was originally thinking about this:
    http://www.vortec.com/cold_air_guns.php
    It requires a full size compressor. The fish tank blower would certainly be easier and cheaper.
    Mar 2006
    427
    and Quieter! This is what I was thinking of picking up.
    Would have posted it earlier but ebay is bad at work
    http://cgi.ebay.com/AIR-PUMP-COMMERC...QQcmdZViewItem
  1. A Cold Few Days....
    By santiniuk in forum European Club House
    Last Post: 06-26-2010, 08:49 AM
  2. cold gun
    By fourperf in forum Fadal
    Last Post: 11-14-2007, 07:28 PM
  3. Anyone for a DIY Cold Saw?
    By damae in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2007, 05:27 PM
  4. How cold is to cold for BP Series I CNC
    By jho5820705 in forum Bridgeport / Hardinge Mills
    Last Post: 12-21-2006, 02:13 AM
  5. Cold forming
    By MBG in forum MetalWork Discussion
    Last Post: 09-28-2005, 04:47 AM
