Well, after a day and a half of heads down and a lot of head scratching (C++ and Qt are some very different animals to what I am used to) I am proud to announce Opti_Qt.
[attachment=0]opti_qt.jpg[/attachment]
Not wanting to make it too complex, I opted for a drag and drop interface.
1. Open the Optimizer (double-click opti_qt.exe) note: the two Qt dlls need to be in the same directory or in your path
2. Open an explorer window to your source .nc file directory
3. Ctrl-click (or shift-click) to highlight 1 or more files
4. Click, drag, and drop onto the Optimizer upper pane
5. The files are processed one after the other. The output files are put in the same directory as the input. The output append _OPT tot he filename.
6. Repeat for additional files and directories
Enjoy, and do report issues and kudos
The application file is large due to the embedded DLLs (3.3MB) but it can't be helped.
Click here to see all of the files available for download.
*** If you downloaded (8 of you ) the executable prior to 7/27/2008 your need the MingW10.dll but I recommend getting the all in one file now.
PS: PCB-Gcode is located here: http://www.pcbgcode.org
