Originally Posted by
boy_gameover
Can these things above use to milling these water blocks.......
NO
But I will expand on this:
The drill chuck is attached by what is called a Jacobs taper; it is simply wedged on. If you put a side load on this by trying to use the drill as a mill IT WILL COME OFF not immediately but it will, and you might finish up with a face full of spinning drill chuck.
The bearings on a drill press are not intended to take side loads and they have too much free play; if you tried milling in a drill press your cutter will wander all over the place.
The table is not rigid enough, the cross sliding vise is not rigid enough.
If your read somewhere, or where told it was possible to mill on a drill press using that vise I am afraid someone was misleading you.
