586,119 active members*
3,439 visitors online*
Results 1 to 6 of 6
    May 2008
    22
    Leaking coolant reservoir
    Has anyone had any leakage issues with the coolant reservoir that Tormach supply to suit the deluxe stand.
    I have just installed mine and find that it is leaking around the mounting point of the pump on the top plate, and also between the top plate and the main reservoir body. The reservoir is no more than half full.
    I noticed when assembling the unit that the reservoir is asymmetric with a baffle arrangement in the middle. Is there a correct way round that the lid should be fitted ?
    Jun 2006
    2512
    There has been lots of discussion on this issue. Search this forum for "leak" and also search here:
    http://groups.yahoo.com/group/tormach1100/
    Phil
    Quote Originally Posted by JTulley View Post
    Apr 2006
    25
    Put more coolant in. It tends to splash at lower fill levels.
    Dave
    May 2008
    22
    Yep, that seems to do the trick. Thanks
    Jun 2006
    3063
    FWIW, I usually run mine with the coolant level at an inch of the top or less with no problems.
    Jun 2007
    168
    That's THE big problem with this system. If the tank coolant level is too low, the pump splash the coolant and it leak from the cover. You can put a seal on the cover to help and install a level gage to always have the correct level of coolant in the tank.
  1. fiberglass gas tank and leaking.
    By krymis in forum Composites, Exotic Metals etc
    Last Post: 07-28-2008, 01:03 PM
  2. Haas TM2 Leaking Coolant
    By Chris Swier in forum Haas Mills
    Last Post: 06-21-2008, 03:57 AM
  3. thru spindle coolant leaking
    By GARY DAVIS in forum Fadal
    Last Post: 03-25-2008, 01:28 PM
  4. Coolant leaking slowly on back of VF3
    By Rocko1 in forum Haas Mills
    Last Post: 12-07-2007, 12:38 AM
  5. Flushing/cleaning coolant reservoir?
    By speedofsound in forum Milltronics
    Last Post: 10-26-2006, 04:01 AM
