Hi. I have one Bridgeport Int. 412X. 1991 model. Control is TNC 2500. Because of the power supply fault, all the parameter was lost. Is there anyone can help to send me a copy of the parameter (hard copy). My email is [email protected]. Thanks.
This is the only list i have for a TNC2500 on a 412.
George
Hi George. This is a great help to me. Thanks.
I was able to contact both Heidenhan and Bridgeport in the UK and they both supplied me the parameters as well as a lot of other information, the only thing is there were a few differences in them so I went with the ones from Bridgeport.
Parameter for Machine Int 412, TNC2500 , form Bridgeport year 1991.
my machine is in working condition.
i also built the power supply by myself. if you need then i can help you.
Hi all
I have a intrect 412x tnc2500 and all in below taxt file.
Hello:
I have a problem in Bridgeport machine the model is VNC 760 DX 32, our problem is because the orientation is bad, we detect that the pulse coder is damage, but We don't have this pulse coder, we have a pulse coder for 2600 PPR and the original is for 500 PPR, we found a parameter for change this characteristic but we don't have the password for write eneable and change it, somebody know about it (password)??? thanks...
code = 785460 I think.
George
Hello
due to replacing battery my initial parameters for Interact 412 (PLC software Num. 250 144 03 -NC software Num. 243000 12)
Can anyone help me & send the initial parameters and start up procedure for this machine?
Thank you very much(flame2)
Hosein
mailto:[email protected]
look above.
thanks.
I've entered parameters & checked them twice but spindle doesn't rotate ever & no error message appear. no other problem is found
what should I do?
please help me....
What is the spindle dirve- fanuc?
What is 412X???? have a VMC412 with a TNC2500 which I can send parameters of...
You have a list of parameters and their function?
Hello
my machine is interact 412 without any suffix
spindle : Fanuc
PLC : Bosch (software Num. 250 144 03)
Control :Heidenhain TNC2500
model:1990
yes I have parameters list but it's better to compare it with others to find spindle problem. if it is possible send me your parameters? ([email protected])
I've read parameters functions but could not understand it.
Hello Please help
Interact 412F
Control Fanuc 0M mate
Need Parameters and PC Parameters
Please PLease......
