586,043 active members*
3,704 visitors online*
Results 1 to 6 of 6
    201
    Spindle Orientation
    I have two yasda ybm640v cnc jig bore machines. I would like to orientate the spinde every 90 deg. Does anyone know what m or g code does this. I have a fanuc 16i-m control.
    156
    If you can't index the spindle in more than one index location. You could consider setting 4 tools and holders at the 90 degrees.
    For broaching on VMC we set addtional broaching tools for each 90 degrees as needed.
    Safety - Quality - Production.
    201
    That is my second choice. I think that will be the way to go.
    Aug 2008
    15
    i reply you after two day by trying on my machine your requirement
    Aug 2008
    15
    i reply you after two days by trying your requirement on my machine
    201
    Thank you
  1. Spindle orientation
    By StampCraft in forum Haas Mills
    Last Post: 11-11-2007, 12:31 AM
  2. Spindle orientation
    By jimecv in forum Daewoo/Doosan
    Last Post: 11-09-2007, 06:25 PM
  3. 16i / 18i Spindle Orientation...
    By Sump Cleaner in forum Fanuc
    Last Post: 09-11-2007, 01:46 PM
  4. Will Mach do spindle orientation?
    By KKutt in forum Mach Software (ArtSoft software)
    Last Post: 04-09-2007, 11:52 PM
  5. Spindle Orientation
    By machinist39 in forum Haas Mills
    Last Post: 05-05-2006, 02:58 AM
