I built a CNC using plans from Solsylva. It works very well thankyou. I started cutting patterns into wood with my trim router spindle until I started frying the bits. I'm not a carpenter and only used routers sporadically in my life, so I know little about feed rates, wood types, etc. I know which bits are best material (carbide) to buy but not how to USE.
I can cut Styrofoam really well!!
My intention is to mill sheet aluminum to make parts for my car and stereo system but I'm afraid to start until I get the feedrate/bit type sorted out. Is there someone who can shed light on this? Is there search words I should look for in particular to find it on this forum? I'd also like to use a laser or plasma cutter with my CNC, so if I can be directed to an area where I can get info that would be great.
Bottom line:
-What types of bits do I use for aluminum (sheet to say 3/16" thick)
-how many flutes (I've read from 0 to 4. How can you have 0 flutes?)
-bit diameter (I have a Dremel, 1/8" collet, and the trim router, 1/4" collet)
-how fast do I feed? (I found out I was cutting my wood too SLOW).
-Cooling required? Alumicut? or something else? Liquid? compressed air cooling?
-spindle speed. My trim router has one speed, about 20,000 rpm. should I consider variable speed?
THanks guys.
