Hi gays
Is there anybadi who knows way to use connector with remarks RS232 at interface PCB at control system OSP3000. And way to load part program from PC to control . Thanks
Hi gays
OSP 3000's had no RS232 interface.
I have a half finished PTR to parallel interface. (fully opto-coupled)
Hardware is done, but I have not had time to program the logic.
It dual ports the PTR and fakes being a PTR or lets the original PTR still work
and snoops the operation as a data analyzer to figure how to make it work.
Not interested in punching out of the OKUMA.
You can find off the shelf solutions.
Google BPTR now returns cr@p.
Is there any recomendation for commercialy BTR. Some low cost solution?
Mine will be commercially available if I ever get it finished.
If there is enough interest I will finish it.
There is no extra wiring to to. It plugs direct in series with the PTR cable and mounts on the existing cable socket. FULLY opto isolated with parallel LPT interface.
