586,119 active members*
3,619 visitors online*
    May 2008
    9
    Another rigid tapping question?
    I have a different problem from what I have seen others have. I have a 18i-TB control using manual guide-i. I have the program working great except for rigid tapping. When I execute the program, everything runs great up until it is time to tap. The live tool spins up and moves to location. Then the spindle stops, looks like it orients itself, and the machine will just sit there indefinitely.
    Now, I can reset the program and restart with the tapping operation, no problem. Tool spins up, moves to location, turns off, orients itself, taps the hole, and finished out the program.
    I have tried using G94 and G95 feed rates with no change. Of course, I am using guide-i so I am not using a G84 command, it uses G1112 for tapping info and G1210 for the position.
    I am stumped as to why it works when executed at the tapping cycle and not when the whole program is executed.
    Any help would be greatly appreciated.
    T.J.
    May 2008
    9
    Anyone have any ideas? I have run out of things to try.
    T.J.
    Apr 2007
    148
    Quote Originally Posted by crash80 View Post
    T.J.
    Post the code where it hangs up so we can look at it. Are you calling out
    M29 prior to your manual guide i tapping cycle? If not you need to. Here is a one from a program that I have run many times.
    (0-80 TAP)N8G00G40G80G90G49
    T8M6
    G54X0.0Y0.0
    G43H08Z1.0
    M29
    G95
    M08
    G1002W1.D0.0125I2.J0.1L-0.15C0.1P0.Z2.R2.S1000
    G1212B0.H0.17V0.925A0.C0.175D0.175E0.26F0.175I0.17 5
    G1212B0.H0.65V0.3A90.C0.135D0.165E0.165
    G1210B0.H0.18V0.625A0.16C0.435D0.19E0.22F1.14I0.62 5J1.16K0.435M1.11P0.22
    G1210B0.H0.36V0.19A0.5C0.075D0.8E0.075F0.95I0.19
    G1210B0.H0.1V0.775A1.2C0.775
    G1210B0.H0.65V0.925
    G00Z1.0M09
    G53Z0.0
    G80G49G94M01
    M5
    G00G40G80G90G49
    M30
    Seems like my version of manual guide i is using G1002 for the tapping cycle and G1210 for the positional data. The M29 syncs the spindle with the Z axis. Try this, run the code I gave you as is and see if it runs ok, if not remove the M29 and see what happens. You most likely will not get much help with manual guide i issues, not to many people program with it. We used it exclusively in the beginning to get us up and running fast, then we switched to using a cad/cam system once we figured out what we were doing Hope this is of some help and let me know how things go.
    May 2008
    9
    Problem solved. I had to put a spindle stop in before I indexed the spindle even though I was not running the spindle. I was indexing the spindle in the operation before the tapping cycle, but I guess the control thought it was in spindle mode.
    Anyway, I added a spindle stop, and no problems since.
    T.J.
  1. Rigid Tapping
    By Teps71 in forum Milltronics
    Last Post: 03-29-2016, 01:23 PM
  2. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  3. Rigid Tapping
    By NinerSevenTango in forum Mach Mill
    Last Post: 11-06-2010, 08:59 PM
  4. rigid tapping
    By damon1313 in forum Fanuc
    Last Post: 07-29-2008, 11:26 PM
  5. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
