586,108 active members*
3,038 visitors online*
    Aug 2008
    9
    Unhappy servo turret alarm
    Help! I just purchased a dainichi f 15 lathe with a fanuc series 21 TB control. The machine is like brand new with only 24 run hours (came out of a college).
    I powered it up and got a servo turret alarm (2048). The fanuc beta series pulse coder had weak batteries. I replaced the batteries but still have the alarm. The led on the pulse coder is flashing 11U. I belive the turret has lost its reference position because the screen shows tool number T00. The manual says to exacute a dogless reference position setting to memorize reference position. How do I do this as I am unfamiliar with this control? Any help would ne appreciated. Thanks, Norb
    May 2005
    109
    Quote Originally Posted by Hifeed View Post
    Each tool builder have different way to zero turret servo. But you can find it on ladder diagram. I can help you if you send me ladder diagram.
    Aug 2008
    9
    Thanks for the help but I contacted Dainichi and they sent me the instructions. I had to change a bit on a keep relay then index the turret to tool 1, change the bit back to the original setting and power down then back up again, I hope this info can be of help to others. The Dainichi people were very friendly and helpful especially Harris. Thanks to all, Norb
    Feb 2012
    Hello,
    I am working on Aeroturn LT280 cnc lathe after prolong period the turret is not getting referred even after replacing the battery to the servo drive MR-J2-60D-S24 which driveing the motor HC-SFS-52K.Kindly guide me the method to do so. If there is any loss or change in its parameter, Kindly let me know.Hoeing the best.Regards.Trilochan Singh
    May 2020
    Re: servo turret alarm
    Hi can you give me some instructions on which keep relay and what you changed? I just bought a dainichi f25 with the same alarm
  1. Daewoo Puma 300 lathe turret alarm
    By rollman in forum Daewoo/Doosan
    Last Post: 04-24-2015, 08:27 PM
  2. Replies: 6
    Last Post: 04-29-2011, 11:20 PM
  3. turret servo adjustment.....
    By theemudracer in forum Fanuc
    Last Post: 05-16-2008, 05:39 PM
  4. QT-200 Turret servo motor
    By andra in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-09-2007, 10:43 AM
