Hi all,
I am learning to cut thread on my C3 lathe and managed to cut an 8mm dia. x 1.25mm pitch thread on a brass rod. It didn't work out as well as I wanted but good enough for a start.
I am doing this on a manual lathe (without a thread dial), i.e. I had to change the gear in order to set the right pitch for the thread.
I am also planning to cnc my C3 lathe in the near future. I know I have to fix a stepper motor onto the bottom leadscrew. This would mean I have to disengage the leadscrew from the gears in the headstock. Without the gears controlling the speed of the rotation of the leadscrew in relation to the rotating chuck, how do I make sure the pitch of the thread will be correct? Does Mach3 have a setting to control the speed of the lead screw for the correct pitch? Thanks in advance.
Alex
