586,094 active members*
4,177 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma OSP 2200 Control
    Jul 2008
    Need to ask some questions concerning Okuma 2200 OSP control, we needing to set backlash compensation parameter. Also looking for a retired or available operator or tech. that can come on site for a few days to train on this control if possible. Thanks, Tim
    Jul 2006
    5
    where are you located. We have two lsn lathe with osp 2200 controls. i have ran these machines for 15 years. Maybe i can help you over the net.
    Doug
    Jun 2006
    30
    There is no parameter for backlash. You need to take off encoder and adjust mounting ring.
    Jan 2009
    74
    backlash setting on the 2200
    -set the mode select to mdi
    -set the display selector switch to data (buffer) position
    -key-in g77
    -press write
    -key in X 00000
    -press write
    -key in z 00000
    -press write
    press cycle start to lock in the value at 00000.
    check the backlash about and repeat with the value you want for backlash.
    *if this is a 2 turret machine do G13 and G14 instead of g77.
    best of luck...
  1. Okuma retrofit Machmotion control
    By KGD in forum Okuma
    Last Post: 04-23-2008, 04:45 AM
  2. okuma OSP500L-G Control with sub-spindle
    By pp-TG in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-18-2007, 11:20 PM
  3. Dyna 2200/2400 Program to Computer
    By basch3 in forum Knee Vertical Mills
    Last Post: 05-05-2007, 02:41 AM
  4. Dyna Conversion from 2200 to Mach
    By New 2 CNC in forum Benchtop Machines
    Last Post: 12-05-2006, 05:46 AM
  5. Okuma VAC-Motor feedback control?
    By DennisCNC in forum Servo Motors / Drives
    Last Post: 10-04-2006, 04:08 AM
