586,612 active members*
3,713 visitors online*
Results 1 to 8 of 8
    Oct 2006
    48
    Is a mini Lathe worth it
    Hey guys,
    I've never toyed with a mini lathe before. We are about to purchase a nice CNC precision tool room lathe (possibly a ganesh or a hardinge with a fagor control) but I was wondering would it be worth the investment to get a mini lathe as well. We make small intricate hardened steel hand/finger parts in the tolerances of .0002. If so, from my readings here it looks like I should go with a Emco or Prazi, yes? CNC as well? or manual? I'm invisioning watch makers work.
    Jul 2004
    218
    Quote Originally Posted by star1280 View Post
    Hey guys,
    Obviously a mini lathe can't compete with a Hardinge or any of the others you mentioned, but it should still be worth it to have a 2nd lathe around to make ancillary parts.
    Oct 2006
    48
    Thanks for verifying that a mini Lathe could not keep the necessary tolerances that the larger precision tool lathes can!
    Oct 2006
    48
    Now i'm reading that most jewelry/watch makers use a mini lathes and machines that run on belt to prevent machine vibration to get the precision needed. So now I'm back to me original question can i get a .0001 tolerance from a mini lathe or precision tool makers lathe or even a swiss lathe? What is the preferred/reliable machine?????
    Oct 2005
    278
    without being sure how mini ,mini might be to you guys,
    but i can imagine an emco doing some tight tolerance when cuts are as light as when fiddling toolgears from brass.
    If a brand new schaublin is within your budget i'm sure you wont be sorry.
    sorry i can't be really specific ,but i'm sure if you visit your local jewel and watchmakers and ask them for brand and dealers for the equipment you might even find a machine upto it locally.
    alltogether i mean that what you ask is possible but mini means minicuts also and with this in consideration you have not asked for the impossible just the barely-affordable imo.
    good luck.
    Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
    Oct 2006
    48
    Oh my I think I'm in love! The 102 TM-CNC looks ideal!! Has anyone played with this one yet? Unbelievable tolerances. Thank you
    Oct 2005
    278
    wuhahahahahahahahaaaa
    102 TM-CNC
    that's a bomb as lathe you'll never regret except when pay-off time comes around once amonth.
    And if the electronics used are in any standard comparible to the lathe you'll be a happy chipmaker for years as far as i can see.And i'm in no way affiliated to these machines to be this positive.
    i know a guy wo owns a old as conventional 102schaublin that still rocks as 20yrs. after production.
    PLS don't do any purchases based on my big mouth though ,cause i just happen to be one of the most inexperienced guys around this place.
    BTW i just want to be sure you are aware of all th facors coming into play when producing to 0.0002 tolerances like the temp. in the measuringroom or just the temp. of the machinist's farts while passing by.
    good luck
    Jul 2008
    90
    Hi Star. I have a microlux 7"x14" and of course a full size lathe. I use the mini lathe quite often. It's really nice to have an extra smaller lathe to get the "petty" jobs done. Now I'm not sure of the tolerances when using the lathe manually. (never bothered, like I said petty jobs) but when I use it in conjuction with my CNC mill the tolerances are great! Here are some pictures of my setup. As you can see, the lathe sits on my CNC mills bed. I use the X and Z axis to move the lathe tool. Very acurate and clean!
    Attached Thumbnails Attached Thumbnails lathe 001.jpg   lathe cutting 003.jpg   100_1183.jpg   100_1194.jpg
  1. Mini lathe and mini mill spindle?
    By ZipSnipe in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2010, 02:13 PM
  2. Converting a Grizzley Lathe to CNC is it worth it?
    By Rich05 in forum MetalWork Discussion
    Last Post: 07-11-2008, 04:51 PM
  3. Is this lathe worth $800?
    By Rich05 in forum Uncategorised MetalWorking Machines
    Last Post: 07-11-2008, 12:32 AM
  4. X2 Mini Mill & Mini Lathe - Cummins Tools
    By ccsparky in forum Benchtop Machines
    Last Post: 12-19-2007, 02:54 PM
  5. I found an old logan 850 lathe for 100 bucks is it worth it?
    By trilect in forum Uncategorised MetalWorking Machines
    Last Post: 06-29-2005, 10:52 PM
