Usually these double vises have a special collar on one end of the screw which may have to be loosened off to allow the jaws to float into position when clamping different width objects. Indeed, this float collar should be adjusted to give a bit of slack so that the jaws can accommodate a slight discrepancy in part width. That way you won't get a surprise loose piece.
Hope this helps. I have a cheaper clone vise which has about a 4" capacity in each side, but it will definitely close right up tight on both ends.
