Hello all,
Since I could not find a sub-forum about BOBs I posted here in general.
I am designing a opto-isolated BOB for my cnc and have some questions about the parallel port connections that I have to make.
I wonder which of the two circuits I have to use to power the optocouplers - the source or the sink one? My parallel port gives 5V at the pins when unloaded but drops to about 3.2V when loaded with about 5mA /I am using UHU servo drive with its optocouplers wired from parallel port pins to ground/.
I suspect I can wire my BOB so the optos are powered from the computer's 5V line and the data pins bring them low. I have read that the sink circuit could give much higher current - in the order of 15-20mA.
The other problem is I have another computer that is generating only 3.3V at its port. Can I wire an opto here to the +5V line or it is not going to be good?
I know some computers produce less voltage at the lpt port pins but wondered why this should be. Or I have to wire it to the 3.3V line then?
The same load which brought the firts lpt port from 5V to 3.2V here made less difference - it dropped from 3.3 to about 3.05V.
I am going to use CNY17-4 devices.
Thanks in advance for any clarification on the subject.
Todor
