586,080 active members*
3,485 visitors online*
Results 1 to 8 of 8
    Jun 2008
    475
    Z goto 0 first ?
    Is it possible to have Z "go to Z" first to prevent possible damage ?
    Right now when I press go to Z, X and Y move to 0 first and stop then the Z goes to 0.
    Thx,
    Steve
    Turn on and configure "Safe Z", under the Config menu.
    Jun 2004
    6618
    Safe Z is a must for me. I use 2.5" on my router as a safe Z because I use toggle clamps. I use .1" on the mill. I also like it to go to safe Z when I hit the stop button. If you have to go back home, the Z is up and it also picks it up in case of a bind or a stall on the spindle. I don't see that anymore yet, but saw it often when I was using the stock X2 spindle motor.
    Lee
    15362
    Hi SScnc
    You can do as ger21 has said or just have the first line of Gcode to be G0 Z1.0 or what ever number you want it to be to clear fixtures etc you do not need a X Y move as this saves a lot of machine movement your machine will then go to your programed part start point which is your part zero
    The only time you need a X0 Y0 is if that is your part start point which you would put under the Z axes Gcode moves
    Also put the same G0 Z move at the end of your program for the same reasion before any G0X---Y--- moves & this will save you any crashing in to things at the end of your program as well
    Mactec54
    The gotoZ button in Mach (which is what he was referring to) is hard coded, if you use it, you need to use SafeZ
    Jun 2008
    475
    That did it.
    Also, I just started writing some G-code for some simple operations yesterday so that info helps allot too.
    Thanks for the help guys.
    Jun 2004
    6618
    Sheetcam has a safe Z setting in it as well. Not sure what cam if any you use. No need to set safe Z then, but I still do it. They call it safe for a reason.
    Lee
    If you want to be really brave, you can change the button function using Screen4 (Mach's screen designer) to execute g-code commands and do exactly what you want. Let me know if you want to know how to do it.
  1. Using GOTO in a mazak program
    By CAMCRASH in forum G-Code Programing
    Last Post: 03-16-2012, 11:31 AM
  2. GOTO Z button
    By TMaster in forum Mach Mill
    Last Post: 05-30-2009, 01:18 PM
  3. GOTO Z
    By monte55 in forum Mach Software (ArtSoft software)
    Last Post: 02-06-2008, 04:03 PM
  4. Need help with IF ,THEN,AND GOTO USING COMMON VARIABLES.
    By XRACERJB in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-31-2007, 02:08 PM
  5. Goto Z's button... also the @#$%#$% wizard...
    By InspirationTool in forum Mach Mill
    Last Post: 04-02-2007, 03:54 AM
