Hi all
We are need post processor for HAAS(model:TM-2), and Fagor( 8055model) machines. Pls. help us.
Hi all
If you have a post for any Haas machines in your library that came with Mastercam, then they should be able to be used with the TM-2. I'm not a Mastercam user as of yet, but probably will be in a few months when we get our new router. I know that with other CAM softwares the posts for the Haas are prestty much universal. I guess it would would only be a matter of setting up a template for the parameters of the TM-2 like the speeds and feeds.
CJH
If you are in dire need you should be talking to Mastercam or your local dealer. as CJH said this post for the Haas comes on the Disk. this is a Tool room mini mill if I am correct a standard 3axis mill and that post out of the box will do the job.
You also did not post what version?
Cadcam
This one works very well, we use it on 3X VMC with mastercam V9
just rename it to use.
regards
Can't Fix Stupid
Cam1 that was nice of you but were is the rest of the post? being the Text file that goes with the PST.
Also be aware if this for Mastercam X or higher this will needed to be uptaded as this will not run as is in "X".
Cadcam
Hi cadcam: That is the post file that I use. I just renamed it to .txt in order to make it easier to up/download.
I wasn't aware that there was an accompanying .txt file that goes with a post file.
In any case the post I supplied works very well on it's own, provided you rename it to .pst.
regards
regards
Can't Fix Stupid
There usually a TXT that is named the same review a small portion of my V9 post dir.
Cadcam
Dear CJH
Thanks for your reply.
