586,471 active members*
3,622 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > ENCO 13 x 40 lathe and VFD
    Jun 2007
    Hello-
    First time poster here.
    Just got an ENCO geared head (308-0233) lathe, and plan to install a VFD to run spindle--no problem with that. A minor issue is the coolant pump, which runs a small 3 phase motor. I have two choices--either replace this pump with a single phase unit, or get a real cheap single to 3 phase converter to do it. Isn't there a simple capacitor only conversion out there for this? If so, is there a reference on-line that could assist with this?
    Thanks!
    Tim
    24223
    If this is a 220v motor, usually fractional VFD's are cheap on ebay, otherwise you could experiment with setting it up like you would an RPC, there are quite a few links here on building tuning etc, this would involve a push button start and some run caps.
    Probably frequent start stops might make this method impractical.
    Al.
    Albert E.
  1. Wanted Enco Lathe Model 110-0818 SWITCH
    By chrysler48 in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2011, 10:02 PM
  2. Wanted Enco Lathe 92030 owners manual
    By A-1autouph in forum Want To Buy...Need help!
    Last Post: 05-01-2008, 11:20 PM
  3. Enco 14 x 14 lathe?
    By dannirr in forum Uncategorised MetalWorking Machines
    Last Post: 04-21-2008, 03:02 PM
  4. Enco 9 x 20 Lathe Restoration
    By warossignol in forum Mini Lathe
    Last Post: 04-03-2008, 08:40 PM
  5. Enco Lathe
    By ccm in forum Mini Lathe
    Last Post: 10-21-2003, 10:34 PM
