586,114 active members*
3,221 visitors online*
Results 1 to 2 of 2
    Feb 2008
    17
    Plasma tip reconditioning
    I have about 100 used plasma tips laying in a box and today I was thinking of a way to recondition them. I was thinking that a swedge tool could be used to reform the copper so that they could be re-drilled. Has anyone seen or heard of such tool. A bullet reloading press might be just the ticket.
    Firebass
    Feb 2004
    361
    you could always try a 'sample' reform by using a machined insert to support the inside of the tip, and lightly peening the top surface to deform and shrink the opening...if it's copper it will 'flow' reasonably well, less so if it's more like bronze..
    another alternative might be to make a lathe insert adapter, and 'roll' deform the surface in towards the center, would probably give less 'thinning' on the tip surface portion..
    or, if it's a 'mostly' copper material, clean up the opening a bit, and then just braze it shut, redrill after, choice of tip openings...
    ..might have to make yourself a 'cleanup' tool to recondition the inner part of the tip, something as simple as a reground drill bit with a protection sleeve..you mentioned a bullet press, something like a primer pocket reamer would probably work as well for inside cleanup..
    ..enjoy..
  1. Reconditioning and rust
    By ozzie34231 in forum MetalWork Discussion
    Last Post: 12-11-2007, 09:18 PM
  2. Using gas other than air on a plasma..
    By hotponyshoes in forum Waterjet General Topics
    Last Post: 02-27-2007, 02:17 AM
  3. 4x8 plasma
    By welderman in forum Waterjet General Topics
    Last Post: 03-21-2006, 07:06 PM
  4. Table reconditioning
    By MrRage in forum Knee Vertical Mills
    Last Post: 02-06-2006, 04:13 PM
  5. What Plasma CNC to buy???
    By flatcreek in forum Community Club House
    Last Post: 11-23-2005, 10:18 PM
