586,119 active members*
3,629 visitors online*
Results 1 to 7 of 7
    Mar 2007
    215
    Can I avoid G28?
    Hey guys. Well I finally got my Hardinge Superslant making parts and money for that matter. I am having a small issue with my programs however. This machine has a Fanuc GN6 control, which took some adjusting on my part to get used to. This control uses G50 to set my tool offsets, which is something new for me. It seems that I have to G28U0.W0. before every tool change or the turret doesn't know where it is. There has to be a way to avoid this, it is increasing my part time quite a bit. Any suggestions would be great.
    4826
    G28 is good protection to assure that the tool is starting from a known position all the time. Multiple G50 calls is a good way to get lost in the woods
    To use one and only one G50 call, you need to set all the tool length/radius offsets relative to a master tool, perhaps tool 1 (a finisher would be good), instead of setting the tools to the part reference point. In this system, you would have tool offsets for the master tool of very nearly Z0 X0, and all the other tools would be relatively small amounts compared to that, because it would only be the difference in position between their tool reference and the master tool.
    So then the G50 call would represent the distance of the master tool from the part (work) reference.
    Now whether the PLC in your controller permits a tool change at other positions other than turret home might be a good question.
    Nonetheless, after a program interruption, you absolutely must return the machine to the G28 before the G50 is re-read.
    Mar 2007
    215
    Hu,
    Thanks for the reply. The tool will change outside of home. I am intrigued by your one G50 method. So, for example, if tool 1 was set to X0.Z0. and my cutoff tool was +.25 on Z compared to tool 1, would you program it that way or use your wear offsets to compensate?
    4826
    Quote Originally Posted by Crashmaster View Post
    Hu,
    Always program the truth. Use the length and diameter offsets to compensate for the difference between the tools. Wear comp is not technically for that purpose, but I'm only guessing at what your offset register looks like.
    Mar 2007
    215
    OK, that makes sense. I'll give it a try, Thanks!
    Jan 2009
    5
    hi mate
    cancel the tool call with a return to safe position in rapid
    G00 X100.Z50. T00
    the T00 is required to cancel the offset
    hope this helps
    Bill
    Mar 2007
    215
    Hi Bill,
    Thanks for the suggestions, I will try it out sometime today.
    Joe
  1. Which would you choose/avoid?
    By mstrsig in forum Commercial CNC Wood Routers
    Last Post: 02-05-2008, 02:51 PM
  2. How to profile/contour and avoid areas?
    By Shepard in forum Mastercam
    Last Post: 12-04-2007, 12:11 AM
  3. Avoid Prosoftstore
    By gwb in forum MetalWork Discussion
    Last Post: 02-15-2007, 06:27 PM
  4. Router But hope to avoid surprises
    By watzmann in forum Community Club House
    Last Post: 04-19-2006, 02:10 PM
  5. How to avoid stinkin' coolant?
    By ESjaavik in forum DNC Problems and Solutions
    Last Post: 10-11-2005, 12:47 AM
