I need a nut. The nut needs to be M24x1.0 (24mm in diameter, with a 1.0 pitch) It does not have to be a hex head. It can be made out of solid round stock (steel). I would actually like a little extra metal around it so I can weld around the outside of it. If need be I can send pictures of the part the nut needs to fit around. I can even take pictures with calipers on the part, if that would make things easier. Thanks everybody.
