586,103 active members*
2,836 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Specific feed speed rates for specific wood
    Oct 2007
    123
    I am working on a project where I am carving a relief into a sheet of plywood, they are forms for the sides of some custom concrete blocks. I am trying it with 3/4" pressure treated plywood, it's pine, (the other option is birch veneer which I think has a softer core like poplar or similar). Anyhow, I'm using a 1/2" endmill, 3/8" x&y step, and have tried with a cut pass depth of 1/8" at 20ipm, that smoked the place up. I tried a faster cut speed at like 60ipm with a cut depth of .07", that seemed to work ok while it was doing straight passes, but smoked up the place again when it started to contour into uncut wood. Am I going about this right to just find the right combination of feed & cut depth? The router is a Porter Cable & is a single speed, I think like 11,000rpm (not sure of that, but almost) here's an image of the sheet I'm trying to cut, it's 8' long & about 3' wide & will be cut out of a 4x8' sheet. You may not be able to make out the cut file image, but maybe you can get the idea.
    This is something that can be done w/ the router right? I just have to find the right combo of cutting tool, feed & cut depth?
    Oh yea, the end mill was a 4 flute solid carbide & I did try a 1/2" carbide straight flute too, same results w/ that. I'm pretty sure that for starters I should try a 2 or 3 flute solid carbide. . . ??
    That third image is of the machine cutting a test panel out of EPS (styrofoam).
    Thanks in advance for any comments or advice.
    --Mike.
    Attached Thumbnails Attached Thumbnails Relief.jpg   ToolPath.jpg   cncRouter1.jpg
    If it's a single speed router, it's probably around 23,000 rpm.
    The smoke is from feeding way too slow. At that rpm you should be cutting at 200-300 ipm, or even faster with a 4 flute tool. As for depth of cut, cut as deep as you can without stalling the router.
    Oct 2007
    123
    Thanks Gerry, that was a great help, I figured I just needed to try some diff. feeds, so here's what I've got working pretty well now. I re-shaped the 4 flute end mill to a 2 flute (the ones I ordered are on backorder!) and I'm running at 100ipm cutting .07" pass depth. I could probably run a little deeper passes but the 3/4" pressure treated plywood is not the flattest and I am only using screws at the edges to hold it down, I don't have a vacuum table, so I have to consider that first pass may run a little deeper in some spots.
    I'll post a few pics of the cut panel here tomorrow or so when I can get some uploaded. The blocks are turning out pretty sweet, I have a bunch that I cast in styrofoam forms earlier, but the wood form blocks are much sweeter (cast 2 of those so far). I think I may be able to get 120ipm from the machine but that's pushing the limits of the Y axis motor at that point & I don't want to risk losing steps.
    Thanks again for the input Gerry.
  1. Looking for specific material.
    By originator in forum Glass, Plastic and Stone
    Last Post: 05-15-2008, 12:00 AM
  2. Are there specific router bits for specific materials?
    By fivefishcnc in forum Uncategorised MetalWorking Machines
    Last Post: 02-24-2008, 02:35 PM
  3. question about drilling speed and feed rates
    By SpYnOnU in forum MetalWork Discussion
    Last Post: 08-11-2007, 11:38 PM
  4. Spindle Speed & Feed Rates - Question
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 07-24-2004, 12:24 AM
  5. Feed rates in wood?
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2004, 03:57 PM
