Also if you go to print, in the Print/Plot screen , look in the Config to see if the default printer is one of the choices, you can make this the default device to print with.
Before you print select Scale To Fit if needed and look at the Full Preview before printing.
Also your pen widths (even though its a printer) can be adjusted in this screen and also Device Requirements etc.
Al.
Albert E.
