Thanks JDenyer. I think that is what we use at work for the drop saw. I only used the WD to clean the table and vise as it had rust from shipping and sitting while I got it set up. I actually thought though that spraying it afterwards and not whipping it off would displace the moisture and keep away the rust,... Not. WD does make a good "Soap" so to say when using scotch-brite to get rid of rust.
So now I have been using the machine more and more and I havent started using coolant yet, and I might not ever use it. I have been using air and with the whipeing down and such to cleanup ect.. the rust isnt comming back. I will start to spray it down as you have said. If the Ultracut is the same as we have it is nice to work with. I'm only cutting aluminum with this machine, so othr than the table galleys I dont really need oil and might not need coolant. Thanks for the info all of you.
Doug
Using CNC Masters Supra Knee Mill, 4 Axis vari speed. Bob Cad V-23, V26, Bob Art
