586,103 active members*
3,398 visitors online*
    Nov 2006
    6
    Understanding extension/overlap
    Hi people,
    In the Profile Operation/Finish window of Solidcam I don't understand the function of
    the Extension/Overlap field and can't seem to enter values that make it alter the path.
    I thought it might do a finishing pass over the roughing wall offset which would be handy.
    Any clues please.
    Cheers,
    Brian Harris
    Mar 2008
    26
    Lets say your are machining a closed profile. You start and end at exactly the same location. Sometimes your tool might flex at that point and it leaves what some in America call a witness mark. The extension/overlap value makes it go all the way around one time and keeps going past the starting point by that value.
    Nov 2006
    6
    Thanks for the explanation, Adam.
    Nov 2007
    330
    Brian, this is a great tool, and I find myself using it as often as possible.
    On one job you could see the witness left by a chamfer tool. I adjusted the lead in and out rads until it was as good as gone, but then overlapped the tool path just 1mm and it was gone completely.
    I'm loving Solidcam!
    Nov 2006
    6
    Thanks mattpatt, and yes, Solidcam's great.
  1. What is a M3P extension
    By bill south in forum Mach Wizards, Macros, & Addons
    Last Post: 12-10-2014, 08:39 AM
  2. Lead Out Overlap
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-23-2008, 02:47 AM
  3. File Extension Question
    By TZ250 in forum Milltronics
    Last Post: 08-06-2007, 02:55 AM
  4. mini lathe extension
    By krymis in forum Mini Lathe
    Last Post: 01-28-2007, 05:14 PM
  5. Extension Cord
    By dneisler in forum Welding Brazing Soldering Sealing
    Last Post: 01-14-2006, 02:29 AM
