586,108 active members*
3,027 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Multiple Work Offsets X3
    Jul 2006
    297
    i am trying to setup 2 work offsets,i clicked on the planes tab and checked the box for work offset and inserted 0 in the field.
    i was under the impression that would automatically add the g55 along with the g54 when i posted.
    seems this tab only specifies the work offset.
    how do i use the transform function to machine 2 parts at a time with 1 tool change?
    in the past when i experimented with transform toolpath function,i didnt like the way it changed tools completed 1 part then went to the other part.
    must be something small i am overlooking.
    thanks
    2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
    Aug 2008
    4
    mx3
    Try using the WCS button. copy your top wcs then add 0 for g54 and 1 for g55.
    I hope that helps.
    Apr 2003
    3578
    Timmy you are good this way, but as Donwayne stated one op needs "0" for g54 and the other needs "1" for G54
    Cadcam
    Jul 2006
    297
    thank you
    May 2007
    71
    thanks
  1. Multiple Work Offsets
    By PinMan in forum BobCad-Cam
    Last Post: 06-06-2008, 10:41 PM
  2. Tl-25 multiple offsets for same tool Help
    By mkmk123 in forum Haas Lathes
    Last Post: 11-24-2007, 01:22 AM
  3. Multiple Fixture Offsets
    By Benji in forum EdgeCam
    Last Post: 05-02-2007, 10:28 PM
  4. Multiple work offsets in mcx2?
    By Bullnerd in forum Mastercam
    Last Post: 03-25-2007, 05:14 PM
  5. multiple work offsets
    By rbest27 in forum Surfcam
    Last Post: 01-25-2007, 10:02 AM
