586,103 active members*
2,578 visitors online*
Results 1 to 2 of 2
    Feb 2004
    361
    Interactive Entry??
    Looked and searched here, but didn't find anything that seemed to fit...
    anyways...
    My question, is interactive data entry possible???
    application is plasma table,
    Mach3 control software..
    basically I'd like to see a prompt such as "Input Desired IPM Feed Rate"
    and then be able to enter desired rate, and have the gcode update, or be applied..
    When I use it, there are quite a few times that I cut the same part out of different thicknesses of material...
    right now I just edit it, but interactive would be "nicer' if possible
    thanks
    Dec 2003
    24221
    Maybe initially program a mean or maximum feed rate, then use a M0 with a prompt message at that point, then adjust the feed rate override to the desired rate.
    Then cycle start to continue.
    Al.
    Albert E.
  1. Looking for an Entry Level CNC machine
    By pk_volt in forum Uncategorised MetalWorking Machines
    Last Post: 06-19-2008, 07:41 AM
  2. Celeritive Technologies Launches VoluMill Interactive™
    By esherbro in forum News Announcements
    Last Post: 11-14-2007, 01:58 AM
  3. New, Free Interactive CD-ROM from SDP/SI
    By carolpratt in forum News Announcements
    Last Post: 12-19-2006, 06:37 PM
  4. M109 Interactive User Input
    By axis overtravel in forum Haas Mills
    Last Post: 07-31-2006, 09:55 PM
  5. Data Entry During Machining
    By squarewave in forum CamSoft Products
    Last Post: 03-21-2005, 06:32 PM
