586,416 active members*
3,961 visitors online*
    Aug 2008
    G02, G03 Feedrate !!!!!
    i'm using Turbo CNC 3.24
    The problem is feed rate do not effect in the G02, G03
    Ex: G02 X0 Y0 I20 J0 F1
    and G02 X0 Y0 I20 J0 F1000
    They runs at the same feed rate, and i don't know what's exact feedrate they are running. Please help.
    Mar 2007
    137
    is there a "G1" IN THE PROGRAM? i.e.: G1 F20
    G1 means feed in a feedrate of 2 or 20 inches per minuit, depending on your software, and G0 means rapid traverse.
    If you cut an arc with the G02 or G03 code, it should still be going the same feed rate as the lines ahead were going.
    Inportant: In the old days, and MAYBE still today, with some cnc controls, in the line after a arc cut with the G02 or G03, you must have a G0 or a G1 so the cnc knows if you want rapid traverse or feedrate. If you don't have the
    G1 or G0, sometimes the machine will just go anyway it wants, untill it hits a limit switch.
    This program is for a fadal. You may need to have an "I0" in the circle line with the J.5
    This will run at 20 inches per minuit, going down the strait lines and through the arc also.
    G0X0.Y0.
    Z.25
    G1Z-.25F20.
    X2.
    Y-2.
    X3.5
    G3X4.Y-1.5J.5
    G1Y0.
    G0Z.25
    Good Luck,
    Buck
    Spring Lake cnc
    Mar 2004
    1806
    USB,
    Going strictly from memory, I think there was a bug in this version with the feed rate on G02, 03!
    Try updating to 4.01 as I know that one works.
    Art
    AKA Country Bubba (Older Than Dirt)
  1. speeds & feedrate
    By barnesy in forum MetalWork Discussion
    Last Post: 06-20-2007, 04:22 PM
  2. Inaccurate feedrate
    By alfalfa in forum CamSoft Products
    Last Post: 05-18-2007, 02:35 PM
  3. feedrate for contouring using v9?
    By rapid in forum Mastercam
    Last Post: 04-15-2007, 01:37 PM
  4. adaptive feedrate
    By camtd in forum EdgeCam
    Last Post: 11-13-2006, 11:59 PM
